lostinthe202 Posted January 28, 2016 Share Posted January 28, 2016 I'm looking for a good used manual trans for my 2000 Legacy, what's the newest year that is plug-n-play? If you're curious about the problem, details can be found here, http://www.ultimatesubaru.org/forum/topic/157471-3revervse-shift-fork/ Thanks! Will- Link to comment Share on other sites More sharing options...
matt167 Posted January 29, 2016 Share Posted January 29, 2016 1999-2004 should be direct. Up to 2006 or even later may work. From a legacy, or if your at the U pull grab an outback trans of same year range. Then grab the rear diff too. You will like the lower gears. You could go for a forester trans and diff in that case too. There the same Link to comment Share on other sites More sharing options...
lostinthe202 Posted January 29, 2016 Author Share Posted January 29, 2016 1999-2004 should be direct. Up to 2006 or even later may work. From a legacy, or if your at the U pull grab an outback trans of same year range. Then grab the rear diff too. You will like the lower gears. You could go for a forester trans and diff in that case too. There the same Right, forgot about the gear ratio thing. This is just a daily driver, so not too concerned with performance. What about Impreza stuff from the same year range? I remember it all have the same bolt/pin pattern, but it's been awhile, more reading must be done. Thanks for the info Link to comment Share on other sites More sharing options...
matt167 Posted January 29, 2016 Share Posted January 29, 2016 Yea, same year range. Just match the gear ratios. Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 29, 2016 Share Posted January 29, 2016 You can use any earlier trans (90-98). If you get one from a car with a cable clutch you just have to move the pivot stud for the release lever and you'll only use 4 bellhousing bolts instead of 8. May need to swap your Nuetral and reverse switches and the bracket for the exhaust hanger. Link to comment Share on other sites More sharing options...
