Another Dead Accell
Time to add my Accell SuperStock coil to the dead list. It decided to crap out on me while about 60-70 miles from home.. Car stalled and would not restart. I got out and looked.. sure enough. oil from the coil had traveled down the coil wire to the cap. The coil wire was twice as big around as the rest of the wires.
Thanks to 78TurboBrat for driving out to the middle of nowhere to bring me parts at 11-12 at night
may return the coil and try a new one, only this time it will be mounted in a vertical type position, see if that helps any.
Maybe an MSD or Mallory coil? Accel has never impressed me personally, but it's just a feeling I have. I think the whole angle thing is BS - the stock ones are fine with horizontal, so unless Accel is skimping on the oil level, I don't see why that would make any difference. Bad design if it overheats at ANY angle I say. But if you have a warrantee..... maybe get a new one, and sell it on ebay. hehe.
Maybe the OE coil's don't overheat because they don't put out as much power.
Wouldn't it get hotter putting out more volts?
Anyway, what can you expect from a $30 coil? I carry my original coil with me just in case.
myself..
i would be curious enough to cut into a un-warranteed accel coil
and try to figure out where it went bad
did the primary coil winding short out?
did the secondary one short out?
did it loose all of the oil in it.. or was there enough to begin with
poor insulation on the coil windings?
Higher voltage should have been taken into account when designing the product.
Both Accel and MSD recommend vertical installation for this reason. I would assume different climates also produce different results. Once again, what do you expect for a $30 coil? I have never heard anyone complaining about the pricier models, just the cheap canisters. You get what you pay for. I haven't read any posts yet where the coil started leaking when it was mounted upright. Now watch mine fail on the ride home. :o
Mine was great for almost a year and then when i swapped in a new engine and used of all things accel wires it took a big crap on me, i'm running the stock coil again and i think i might upgrade to a better one again, but making sure that its vertical, which i guess is easy insurance if they don't like to be sideways.
From following the USMB, it seems that there are lots of folks running the Accel 8140. Mine is fine - so far. Mounted same as original, no problems. About 10 months old. How old was it when it failed?
should have paid $50 for the chrome version instead of the $30 yellow coil :P
my brat's had an 8140 in it for a few months now, no problems. my wagon's had one in for the better part of a year but i rarely drive it..
Be good idea to buy the HIGH VIBRATION Coil offered by Accel or MSD. These coils are epoxy filled (instead of oil filled) which makes them tougher and mountable in any position (even upside down). Highly recommended for rally, offroad, and jumping your subaru :brow: .
i dont even know why im running the damn thing, other than its chrome, and new. everybody just biches about them, but coils go out all the time, thats why they stock them at the parts store.
has anybody ever put one on and gone, damn, my car pulls harder? or damn, it straight fixed my high load pinging? didnt think so. maybe the stock one works good, i got a spare under my seat.
Quote:
"About 10 months old."
Caleb-
You really know how to set a man's mind at peace. You were supposed to say that you've been running an Accel 8140c in the horizontal for the last 15 years with absolutely no trouble. Now I really wish I'da hung on to the old one, and I'll have to double up on my anti-anxiety meds.
Bill
Been around alot of cars for a long time and that was my first to see a coil do something like that, but then again, i dont have the yellow accel coil, or have a need for it. on the turbo brat i am just running the stock coil off the ea82t car. mounted in a verticle posistion.
And Caleb, no problem at all having to save your day. Just remember your running a F.O.R.D. Part. Found On Road Dead. Might want to through that wrench and an extra coil in the back of your car.
Still havent secured mine and its a couple years old now. I offroad it all the time and for a while it wasnt even in the bracket; just flopping around the engien bay.
I'm with archemitis on this; they just break. I've had 2 OEM ones go out for no visible reason. If they typicaly lasted "20 years" parts stores wouldnt stock them becuase ppl would rarely be buying them.
I'll just replace my Accell Super Stock with whatever is cheapest when it breaks :)
  • 3 weeks later...
I owned my chromy 8140 for 2 weeks now...dead :dead: the ig. module was out, too. Perhaps one killed the other. either way, I threw my dying stock coil back in and she fired right up...swapped them one more time in case it was a fluke, it wasnt. I mounted it vertically and even put a peice of rubber mat between the coil and the bracket to dampen vibration. Whats the comparable MSD p/n? or maybe I will play the safe road and go with stock...
This is not good news...........I installed an 8140 back in Dec. and have it mounted in the stock position.
My old coil was not stock, it was a Bosch "blue" coil from a VW............3.4 ohms across the small terminals (I had a low-end miss). The Accell has 1.2 ohms.
I doubt it is any better than stock, but I don't have the stock one to compare it to.
A good idea was put forth earlier in the thread: If mine dies, I volunteer to "cut it open" and see what the heck is in there,, as well as electrical measurements (I have a Fluke 77BN).
Until then, maybe I should go to P-n-P and pick up a spare? :-\
