beamsbox Posted February 2, 2016 Share Posted February 2, 2016 (edited) Just installed a Weber 32/36 DEGV this weekend. I wasn't sure what to do with the vacuum port on the EGR, so I left it alone. Drove 300 miles home just fine and super smooth. Got in touch with Weber and they said to remove the screw-type plug from the front left port on the Weber, so I did. Hooked a vacuum line from that port directly to the Weber last night. This morning on the way to work, the car would hesitate and/or stumble, no noise, just bog down a bit on the acceleration and randomly pick back up. Ran fine yesterday, so I unplugged the vacuum line to the EGR. Now it runs super smooth again. Forgot to add, EGR was recently cleaned, and the intake EGR ports were cleaned during the Weber install. EGR seems to operate properly, opening and closing as I rev the throttle up and down. So, I've read that keeping the EGR is ideal, but not necessary. Am I missing something on the install, I thought it should be direct from Weber to EGR? Any explanation would be appreciated. Thx all. EA81 GL 2dr Hatch Edited February 3, 2016 by beamsbox Link to comment Share on other sites More sharing options...
thornleyjacob Posted February 3, 2016 Share Posted February 3, 2016 I did a delete for the EGR. http://www.ebay.com/itm/EGR-Delete-Block-Off-Subaru-SVX-XT-Loyale-Brat-1600-1800-TBIM-/151393859173?hash=item233fc6f665:g:edwAAOSwHnFVmUlK&vxp=mtr Runs fine without. Link to comment Share on other sites More sharing options...
skishop69 Posted February 3, 2016 Share Posted February 3, 2016 (edited) There is either a thermal vacuum port on the engine or an inline vacuum delay for it. EGR is only supposed to come on during harder acceleration after the engine warms up. By hooking it directly to a ported vacuum source, you're causing it to open when you crack the throttle. If you're in an emissions inspection area, you'll have to hook it up right or they'll fail you. If you're not, use the delete from above. All it does is reduce NOx, nothing else. Just paid attention to where you are. If the car is older than 25 years, you don't get emissions. Get rid of the EGR. Edited February 3, 2016 by skishop69 Link to comment Share on other sites More sharing options...
beamsbox Posted February 3, 2016 Author Share Posted February 3, 2016 Haha. I can def do that. I broke the thermal vacuum port during the weberization anyhow. So I won't really benefit from the lower combustion temperatures induced by the EGR? Link to comment Share on other sites More sharing options...
ezapar Posted February 5, 2016 Share Posted February 5, 2016 If you can find time to drive it over her some time, I can take a look and jog my memory to see if it's all hooked up right. It's pretty simple when all done, but tough to picture without it being in front of me. Link to comment Share on other sites More sharing options...
beamsbox Posted February 5, 2016 Author Share Posted February 5, 2016 Can do. Problem is, I broke a port on the thermal vacuum port. So, without a temp switch on the vacuum line I don't think the EGR will work right anyway. Truth is it runs great without the EGR at all. Thx, Ezap. Link to comment Share on other sites More sharing options...
ezapar Posted February 6, 2016 Share Posted February 6, 2016 Usually, the EGR gets plugged with a cover or just capped off. Link to comment Share on other sites More sharing options...
Subarule Posted February 6, 2016 Share Posted February 6, 2016 Mine is capped off and Weber runs beautifully. Link to comment Share on other sites More sharing options...
beamsbox Posted February 6, 2016 Author Share Posted February 6, 2016 Ya, currently capped. I see no point to pay for cover at this point. Link to comment Share on other sites More sharing options...
