rugbyben Posted June 2, 2004 Share Posted June 2, 2004 Are small chips in your wind sheild fixable? I have several very small stone chips, I just dont want them to turn into cracks. Does anyone know if winshield repair is actually a solution or just a band aid? and does it cost a lot? Link to comment Share on other sites More sharing options...
northguy Posted June 2, 2004 Share Posted June 2, 2004 Personally, I don't believe in the process. What's happening is that a high resin glue is injected into the void and cured. Some cracks/chips can be "fixed" - most can't. If insurance will cover a replacement, and if you have a reputable shop, go the full route. If not, drive it until it's unsafe and find a shop that will remove all of the original material (urethane) and start from scratch on the pinchweld. Do not settle for the close-cut method. Bad news. Link to comment Share on other sites More sharing options...
rugbyben Posted June 2, 2004 Author Share Posted June 2, 2004 bad news because it leaks? Link to comment Share on other sites More sharing options...
northguy Posted June 2, 2004 Share Posted June 2, 2004 Leaks are one of the problems. Some people do a really poor (uneven) cut out and the method of application is to just put a bead of new urethane down. Uneven surfaces result in uneven pressure points = breakage. Additionally, the windshiels was designed to be part of the structural strength in a rollover from about 1985 and up. With less urethane to actually hold the shield in place, the rollover strength is decreased, as well as the possibility of holding an occupant in the vehicle in the event of a front-on collision. Link to comment Share on other sites More sharing options...
rugbyben Posted June 2, 2004 Author Share Posted June 2, 2004 wow and i just thought it was to keep bugs out of my teeth. We do have an actual Auto-Glass shop here that does nothing else, so i would go to them when i need to fix it, bytthe way im waiting until it cracks. and I will go armed with some information and questions to ask. Thanks! Link to comment Share on other sites More sharing options...
charlierh2 Posted June 2, 2004 Share Posted June 2, 2004 watch out for have insurance pay for a small thing like that. ur premiums will go up^ up^ up^. Link to comment Share on other sites More sharing options...
Lesbaru Posted June 3, 2004 Share Posted June 3, 2004 I had a chip and got the epoxy-treatment before it turned into a crack. Did that about 2 years ago, and I haven't had any problem with it yet. The company (Guardian Auto Glass) will only do that to chips on the passenger side of the windshield. If it's on the driver's side, they say you should really replace the whole thing, because the epoxy does leave a little mark and distort your view a bit. Cost me $30. Link to comment Share on other sites More sharing options...
Will Smith Posted June 4, 2004 Share Posted June 4, 2004 several insurance companies will cover the entire cost of the epoxy repair if you have glass breakage coverage. They figure it will keep it from cracking until you trade it in on a new one. Link to comment Share on other sites More sharing options...
rugbyben Posted June 4, 2004 Author Share Posted June 4, 2004 interesting.. the chips i have are on the drivers side, there are about 5, and they are very small. they look like very tiny water droplets, thats what i thought they were until i ran the whipers and nothing happened. most are nto very deep except for one. it is very strange how it is so mall but it is like a hole about have way thru. it resembles a pit like you get in chrome, very strange. thats the only one im worried about. I am hoping it will make it through the summer, but im pretty sure it will crack the first time it gets ice on it. Link to comment Share on other sites More sharing options...
