OldRuffian Posted February 7, 2016 Share Posted February 7, 2016 Was unable to find any info on this, I'm sure it's been asked before. Will the 5 speed single range 4wd transmission from a 91 loyale bolt up to an Ea81 motor? I have an 85 brat and a spare EA81 out of another 85 brat, possibly purchasing a 5 speed single range 4wd transmission, just wondering if and what I would need to make this work. Picture of the brat for posterity. Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted February 7, 2016 Share Posted February 7, 2016 It's the same as a 5 speed d/r swap. Besides you need all the electrical/vacuum parts to operate the 4wd or you can operate it with a cable. You need a ea82 flywheel and clutch assembly (or machine the ea81 flywheel to ea82 specs), shifter with linkage, and the 2 piece drive line or get the brat one lengthened. Cross member is your choice there is a bunch of ways of doing it. 1 Quote Link to comment Share on other sites More sharing options...
