Hi :)
The blower motor in my 1997 Legacy GT Wagon will sometimes make rattling noises. I'm trying to remove it for inspection. I got the glove box out and the three screws that secure the blower. However I cannot remove the motor because part of a metal supporting piece is blocking the exit path. I've tried rotating the motor housing hoping to find a way out but no luck. Do I need to remove more adjacent parts to get the motor out?
Thanks for your reply.
Update: And of course 5 minutes after I posted this, I tried again and found the one orientation of the assembly that gave me just enough room to remove it. :rolleyes:
Edited by mrfixiter
I usually remove the one screw on the side of the dash behind the little D shaped cover. Then one or two on a bracket under the dash in the corner. That allows you to pull the corner of the dash out about 2" and gives more room to remove the blower unit.
  • Like 1
