mrfixiter Posted February 7, 2016 Share Posted February 7, 2016 (edited) Hi The blower motor in my 1997 Legacy GT Wagon will sometimes make rattling noises. I'm trying to remove it for inspection. I got the glove box out and the three screws that secure the blower. However I cannot remove the motor because part of a metal supporting piece is blocking the exit path. I've tried rotating the motor housing hoping to find a way out but no luck. Do I need to remove more adjacent parts to get the motor out? Thanks for your reply. Update: And of course 5 minutes after I posted this, I tried again and found the one orientation of the assembly that gave me just enough room to remove it. Edited February 7, 2016 by mrfixiter Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 8, 2016 Share Posted February 8, 2016 I usually remove the one screw on the side of the dash behind the little D shaped cover. Then one or two on a bracket under the dash in the corner. That allows you to pull the corner of the dash out about 2" and gives more room to remove the blower unit. 1 Link to comment Share on other sites More sharing options...
