EA82 Fuel Pump
Hello all.   I need a new fuel pump for my carbed EA82 wagon.   Has anyone ever bought one from RockAuto or local parts store?   Or know of a replacement brand and part number?
  I would like to go with a new one ... ie, not used.
Roach Auto database is very inaccurate.  They will send you a wrong part and you will pay for the return shipment.
We have plenty of threads here about new/replacement fuel pumps.  I believe Ford's pump will fit.
Try to search.
Good luck,
Sam
Thanks for the replies... however, I must be missing something.    I read about the Ford F-150 fuel pump ... but I thought that was EFI.
  My 1985 EA82 wagon is carbed.
Jeszek, did you put a new fuel pump in your Beast?   If so, what year F-150 should I be telling the parts guy to lookup on his computer?
... Jeszek, did you put a new fuel pump in your Beast? ...
No, it continues functioning with its original one which already has more than thirty years old; the Weber carburetors really doesn't need too much pressure; I've used my "BumbleBeast" for almost ten years without the fuel Return line hooked, and now a year with the return line hooked, it really doesn't make any difference in the fuel supply nor on the carburetor's behaviour.
A Carb fuel Pump has a Diaphragm, and that delivers fuel at around 2-3 psi, while the EFi fuel Pump has a Rotatory Vane, and delivers fuel at around 50 psi; too much pressure for Carburetors.
Sorry for the confusion, my mistake.
Kind Regards.
