meatloafclark Posted February 12, 2016 Share Posted February 12, 2016 Have an idle problem with 89 GL ea82. Just put new tps in and didn't solve the problem. It's revving up to 3000 when I engage the clutch, and also when I'm just coasting it goes up to 3000rpm. It's not overheating, heads seem good no leaking. I'm thinking clean throttle body and maybe adjust the throttle position isle voltage? Any suggestions? Thanks, long voyage Sunday so any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 12, 2016 Share Posted February 12, 2016 Start by Checking for Vacuum Leaks / any unmetered air source. Spraying Carb Cleaner around the intake will help by find idle speed variations. Kind Regards. Quote Link to comment Share on other sites More sharing options...
meatloafclark Posted February 12, 2016 Author Share Posted February 12, 2016 Thanks! I am re adjusting tps and checkin vacuumed tomorrow Quote Link to comment Share on other sites More sharing options...
machineit Posted February 15, 2016 Share Posted February 15, 2016 Have an idle problem with 89 GL ea82. Just put new tps in and didn't solve the problem. It's revving up to 3000 when I engage the clutch, and also when I'm just coasting it goes up to 3000rpm. It's not overheating, heads seem good no leaking. I'm thinking clean throttle body and maybe adjust the throttle position isle voltage? Any suggestions? Thanks, long voyage Sunday so any help is appreciated. Quote Link to comment Share on other sites More sharing options...
machineit Posted February 15, 2016 Share Posted February 15, 2016 Check the water temp selinioid, sounds like that may be giving false reading making it run as if it were cold, good luck Quote Link to comment Share on other sites More sharing options...
DaveT Posted February 15, 2016 Share Posted February 15, 2016 Coolant temp sensor is something to check. Quote Link to comment Share on other sites More sharing options...
meatloafclark Posted March 8, 2016 Author Share Posted March 8, 2016 Coolant temp sensor did the trick! Thanks! Quote Link to comment Share on other sites More sharing options...
firehawk618 Posted March 9, 2016 Share Posted March 9, 2016 Funny how a $20 dollar sensor can cause all kinds of issues on a fuel injected rig. Quote Link to comment Share on other sites More sharing options...
DaveT Posted March 9, 2016 Share Posted March 9, 2016 where do you get one of those for only $20.00? Quote Link to comment Share on other sites More sharing options...
