ajp Posted February 22, 2016 Share Posted February 22, 2016 84 GL wagon 1.8 non-turbo 4x4. The past few days when I start the motor, it sounds like the starter motor gears aren't fully engaging, kinda goes in and out and I hear the sound of metal teeth grinding. So far, it seems to be worse when the car is cold. I have been parking on hills just in case, but it has started the last 10-15 times, sometimes with noise, and sometimes with none. The starter is hardwired to a push button toggle on the dash as the ignition switch went out 10 years ago. Do I need a shim job, or a complete overhaul. Could it be an electric problem? More importantly, is this something that needs immediate attention? - Will I do unrepairable damage if I let it go too long? I have a hunch, but would like to hear the voice of experience. Link to comment Share on other sites More sharing options...
naru Posted February 23, 2016 Share Posted February 23, 2016 Grinding sounds are not good. Probably a bad starter drive. Looks like complete starters are cheaper than buying it seperately though. 1 Link to comment Share on other sites More sharing options...
zmarrott Posted February 23, 2016 Share Posted February 23, 2016 just replace the starter. i had starting issues for a long time of only hearing a click and i kept getting told, its the switch not the starter cuz a starter needs lots of use to go bad. i also have push button start as my key ignition looks like it got hit my a meat grinder...anyways, after replacing the starter a few months ago, ive had zero starter related issues. you can get them from your local parts store for a decent price. 1 Link to comment Share on other sites More sharing options...
ajp Posted February 24, 2016 Author Share Posted February 24, 2016 thank you for the replies! Link to comment Share on other sites More sharing options...
superpoo93 Posted February 24, 2016 Share Posted February 24, 2016 Is the starter loose? Could be... Maybe not... Link to comment Share on other sites More sharing options...
ajp Posted February 26, 2016 Author Share Posted February 26, 2016 not loose Link to comment Share on other sites More sharing options...
