D3F0 Posted February 22, 2016 Share Posted February 22, 2016 Today I did a funny thing because of the way I built the back for my car I ruined everything and anything that was stock. I wanted to do a center exit but it was too much complexity. So I cut a hole in my already insane trunk. Another View Then i Welded in some hangers Checked the exit Pulled it all apart and welded everything I will redo this all mendrel bent pipes soon Back View This is going to have a legeacy resonator installed too with no cats. Shouldnt be too loud with EA82 But with Ej205 i am sure it will suck haha Link to comment Share on other sites More sharing options...
rpholz Posted February 24, 2016 Share Posted February 24, 2016 Why would you place the muffler in the car? Link to comment Share on other sites More sharing options...
D3F0 Posted February 24, 2016 Author Share Posted February 24, 2016 Its not going to be in the car to make it safe this is just the beginning of that project took me a few hours. i am going to build a box around it seal it off properly make it all air tight and hidden so I can pass inspection. Just the best place I could think of to help with ground clearance and all that. Link to comment Share on other sites More sharing options...
Rust Posted February 24, 2016 Share Posted February 24, 2016 looks like your building the perfect pizza delivery car, the trunk warmer option. 1 Link to comment Share on other sites More sharing options...
D3F0 Posted February 24, 2016 Author Share Posted February 24, 2016 Haha exactly! Link to comment Share on other sites More sharing options...
ferp420 Posted February 24, 2016 Share Posted February 24, 2016 why not just straight pipe it and be done with it Link to comment Share on other sites More sharing options...
rpholz Posted February 24, 2016 Share Posted February 24, 2016 Ground clearance in what way, I've had axles hit the gas tank and exhaust piping before the muffler comes close to hitting anything Link to comment Share on other sites More sharing options...
D3F0 Posted February 24, 2016 Author Share Posted February 24, 2016 next update will explain better in pictures. Also yea no one really fabricates things these days. Instead of asking why how about you ask your self why not? That is the whole point of my truck framed RX. I wanna see how crazy I can build a car. i made new mounts for the whole back end I saved this car from death. Its almost rust free right now. Since I cut the stock location out so I ended up moving the muffler into a new home. so the muffler went into a similar area just higher up so i can build skid plates and all that. Link to comment Share on other sites More sharing options...
rpholz Posted February 24, 2016 Share Posted February 24, 2016 Oh, so your lifting it? Link to comment Share on other sites More sharing options...
D3F0 Posted February 25, 2016 Author Share Posted February 25, 2016 I will lift and drop this car depending on the season. Winter run a 2 inch lift with blocks and prelude springs and svx front struts and summer some type of coil overs/ground control set up. Just figuring out what to do with coil overs because I want at least 6 inches of suspension travel and that is not easy to make or buy cheaply. Link to comment Share on other sites More sharing options...
rpholz Posted February 25, 2016 Share Posted February 25, 2016 That sounds like a huge pain in the rump roast Link to comment Share on other sites More sharing options...
D3F0 Posted February 25, 2016 Author Share Posted February 25, 2016 Just swapping suspension around its not gonna be to bad lol. Starting to block this thing off this is a mock up for this box I am going to have it so I can bolt it in and use some kind of gasket to make it seal perfectly. Link to comment Share on other sites More sharing options...
