unibrook Posted February 24, 2016 Share Posted February 24, 2016 2001 Forester 5MT with 143k on her. The slave was replaced 4 yrs ago, the master replaced 6 months ago, and the clutch plates and flywheel replaced 4 months ago. The clutch pedal does not act soft or spongey at all now, the way it did when the master or slave was going bad. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 24, 2016 Share Posted February 24, 2016 Any less difficult if you press the clutch pedal twice? If you press the pedal then wait 3-5 seconds before trying to move into gear? Quote Link to comment Share on other sites More sharing options...
gbhrps Posted February 24, 2016 Share Posted February 24, 2016 unibrook, I would rebleed the slave cylinder or replace it, and then consider replacing the tranny fluid with RedLine MT90. This is where I would start. Good Luck! Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 24, 2016 Share Posted February 24, 2016 if you have synthetic gear lube in the trans, switching to a non-synth GL-5 might help. Quote Link to comment Share on other sites More sharing options...
