mkc1962 Posted February 24, 2016 Share Posted February 24, 2016 In doing my rebuild, (82 brat 4 spd) I'm wanting to replace all of the Transmission as well as rear Differential output shaft seals. Meaning the seals that the CV shafts lock in to. Ive ordered a few that fit the verbal description using Rockauto as the source, but what has arrived is no where near the proper seals. Has anyone out there recently ordered these seals I mention, and can make reference to any propr part #'s? Any info appreciated. Link to comment Share on other sites More sharing options...
mkc1962 Posted February 26, 2016 Author Share Posted February 26, 2016 Anybody? Link to comment Share on other sites More sharing options...
DaveT Posted February 26, 2016 Share Posted February 26, 2016 If you can measure the id and od and thickness, you can try bearing supply houses, amazon, ebay. You are looking for double lip shaft seals. Link to comment Share on other sites More sharing options...
mkc1962 Posted February 27, 2016 Author Share Posted February 27, 2016 Yes I can go that route....but was hoping to find some info for seals that others have acquired for the application. I cant be the first person to ever have a CVshaft seal start leaking. Link to comment Share on other sites More sharing options...
two85s Posted February 27, 2016 Share Posted February 27, 2016 Aside from DaveT's good advice, call a dealer or an online Subaru OEM parts seller when you have some time to get through to a person. I forgot the one that helped me with ordering factory parts but the guy was knowledgeable and looked up several parts based on the year, make, & model. With his computer he was able to report how many were left, in the country, of this or that and give me a price. All the dealers I tried to call were a waste of time because I usually was left to "leave a message". Many of the parts are NLA, no longer available, but many ARE still available. Those don't seem like they would be uncommon or very expensive. I would like to get some for future use so I am curious as to what you find. Good luck and post what you find. Cheers & thanks. Link to comment Share on other sites More sharing options...
mkc1962 Posted February 27, 2016 Author Share Posted February 27, 2016 Ive tried 2 dealer sources so far with no luck other than the generic answers you mentioned. I Have no doubt If I were to remove them it is highly possible I can read an existing number on the seals and maybe eventually find them through some sort of cross reference. But I did not want to remove the ones that are in until I had new ones in hand. In the case of Rock Auto they clearly show, and I have in hand what does appear to be a cv shaft seal for something, but it is also quite clear they are no where near the proper size. I may have to resort to pulling axles and leaving it up on the lift until I can find something that works. If I find anything I will post here. Link to comment Share on other sites More sharing options...
DaveT Posted February 28, 2016 Share Posted February 28, 2016 I just remembered to go look at one now. They are an odd / different style than I thought for the rear diff, anyway. I saw a marking, but couldn't read it. Have to try when there's more light. But now I checked, mine are all newer, so I don't know if they are going to be the same. Link to comment Share on other sites More sharing options...
naru Posted February 28, 2016 Share Posted February 28, 2016 Rear CVs do not have seals,but,the stub axles do. 8067 32030 Same for the Front 8067 27040 LH,....27030 RH Good luck getting Subaru to look them up. Even if those slackers had a parts catalog,it says the RH one is auto only Link to comment Share on other sites More sharing options...
