desertsubaru Posted February 24, 2016 Share Posted February 24, 2016 Was cruising along in my 2003 Forester when my top rad hose blow spewing coolant all over the place soaking the Alternator. now at an idle the gauge reads normal and battery light is not lit. At higher revs gauge goes all the way up and light comes on but then drops when rpms drop. So what is you guys and gals opinion on this? Did it just get the internal regulator wet and shorting it out which will cure itself when dry or am i going to have to get a new alt? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 24, 2016 Share Posted February 24, 2016 The internal regulator got wet and probably is on its way saying goodbye... Quote Link to comment Share on other sites More sharing options...
TOONGA Posted February 25, 2016 Share Posted February 25, 2016 Yes the regulator is overcharging I would say one or more of the components got damaged when the alternator got soaked. Either get a new one or a good second hand unit. TOONGA Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 25, 2016 Share Posted February 25, 2016 I don't know in your Area, but here in Honduras, we simply go to a store like ~► This, obtain a brand new internal regulator and ball bearings, and renew fresh any alternator; which is a cheaper and easier option than sourcing another one... Maybe this information can guide you, in case you want to renew your alternator: ~► http://www.subaruforester.org/vbulletin/f85/rebuilding-alternator-117340/ Kind Regards. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 25, 2016 Share Posted February 25, 2016 Be aware when voltage regulator is not working properly, that it will over charge the battery, most likely to boil the water out of the battery, and ruin said battery. Result will be that your battery will fail to start the car. I wouldn't drive too far, you need to replace the alternator. Not a bad job swapping out an alternator on a Subie. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 25, 2016 Share Posted February 25, 2016 Could it just be the belt slipping? Light coming on doesn't necessarily mean its overcharging. Have you checked it with a voltmeter? Worse than damaging the battery, overcharging can fry your control modules. By modules, (plural) I mean ALL of them. 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted February 25, 2016 Share Posted February 25, 2016 Belt slipping can't cause overcharge. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted February 25, 2016 Share Posted February 25, 2016 ... overcharging can fry your control modules. By modules, (plural) I mean ALL of them. Also, I've seen some cars that got the Stereo Fried with overvoltages. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted February 25, 2016 Author Share Posted February 25, 2016 Could it just be the belt slipping? Light coming on doesn't necessarily mean its overcharging. Have you checked it with a voltmeter? Worse than damaging the battery, overcharging can fry your control modules. By modules, (plural) I mean ALL of them. I have a Gauge and a light. Gauge goes all the way up then light comes on. Also checked with voltmeter and there is an over charge to about 18 volts. When it first happened after fixing hose the gauge stayed pegged on high with light on. Then I drove it home and let it sit for about an hour. I then went back out to start it to move it out of my way. When it started and idled normal gauge was normal and light was out but after revving to above 1500 rpms the gauge shot up and light comes on, when rpms drop it is normal. I am not driving car now and will let sit for a few days to see if it drys up, If not I have another alt I can put on it. Quote Link to comment Share on other sites More sharing options...
DaveT Posted February 25, 2016 Share Posted February 25, 2016 Good idea to not drive it. That describes a regulator the is "stuck on full" . I just had one fail that way on one of my loyales. I ordered parts from aspwholesale.com Quote Link to comment Share on other sites More sharing options...
Numbchux Posted February 25, 2016 Share Posted February 25, 2016 +1 for probably failed regulator, maybe more damage. If it was my only car, I'd go to my local parts house and buy a reman alternator. If I had another car and/or alternator, I'd give it some time before buying a new one, but definitely don't drive it like that. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 25, 2016 Share Posted February 25, 2016 +1 on swapping in a new alternator. A + 18 volt reading tells all. Don't damage the electrical system running your current bad alternator. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 25, 2016 Share Posted February 25, 2016 Pull the green connector off and make sure it isn't full of coolant inside the connector. Clean it out with contact cleaner and let it dry or use compressed air to blow it dry. Quote Link to comment Share on other sites More sharing options...
powderhound Posted February 25, 2016 Share Posted February 25, 2016 Go to a parts yard and buy a used one. Hell, they're so cheap buy two. After struggling with shitty rebuilt napa gold alts I went to the yard got a used one rebuilt by fuji for 20 bucks. It's a no brainer. Quote Link to comment Share on other sites More sharing options...
Olnick Posted February 25, 2016 Share Posted February 25, 2016 +1^ What powderhound said. My son grabbed one from Pull n Pay yard and it worked great for the life of the car! Quote Link to comment Share on other sites More sharing options...
jp98 Posted February 26, 2016 Share Posted February 26, 2016 Getting a used one out of a junk yard sounds nice but for a lot of us the nearest one may be over 100 miles away. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted February 26, 2016 Author Share Posted February 26, 2016 Went out today and battery was dead. Must of drained because of volt reg being bad. No other drains were detected. Going to bolt alt I have on when weather clears. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted February 26, 2016 Share Posted February 26, 2016 Went out today and battery was dead. Must of drained because of volt reg being bad. No other drains were detected. Going to bolt alt I have on when weather clears. If your battery has caps on the top, pull a cap or two, and look into the battery. The battery may be low on water because of the over charging. The over charging actually evaporates the water from the battery. If so, add distilled water to the battery, and you may be able to save the battery. However, it is a possibility that the battery is now ruined. Quote Link to comment Share on other sites More sharing options...
