'86 GL Wagon Original Clock - Weird
Every once in a great while the clock will come on briefly. Just flash on. Like, when I'm shutting off the engine. Then if I immediately turn the key on without trying to start the engine, to see if it will do it again and it might come on again, briefly.
Otherwise the clock seems dead. The clock hasn't worked in at least 15 or 20 years.
What does it mean when the clock decides to function for a few seconds? That it would work if.....??
Any ideas?
  • Like 1
That's all it could be - the solder joints?
I don't know how to solder. Or take the clock out. I really wasn't looking to fix the clock.
I was just wondering why the clock would occasionally come on after acting dead for so many years. I mean, what could trigger it?
Once you figure out how to remove the clock just google "cracked solder joint repair"  There's dozens upon dozens of how to's available.
It's not hard and you can get by with a cheap $15 dollar radio shack special.
If you want to mail it to me I would go through and re-solder them all for you at no cost to you other than return postage.
Should I feel blessed that the clock in my 86 seems to work just fine?  :)
Edited by firehawk618
  • Like 2
I'd like the clock to work but it's not a priority since our cell phones give us the time. And I still wear a watch.
I'm a little old lady (yes, my Sube is a little old lady car) and I have no car repair skills. Or tools.
I'd be happy to let someone knowledgeable & capable fix my clock, if some one in SW Washington is so inclined.  :)
If you wanted to pull it and mail it to me I could clean up the solder joints.  No guarantee this would fix it but it's worth a try.
I am working on a repeatable fix and upgrade for the clocks.
The main failure is caused by the cheap zener diode and resistor regulator to drop 12V down to 5 that the clock IC runs on.  The power wasted in the resistor is too high, especially in summer when the dash is in direct sunlight, thus the connections fail.
The other problem they have, is occasionally forgetting the time when starting the engine, which I have fixed by adding a couple of parts.
The 2 I have modified and installed in my cars have been flawless for a good while now.
  • Like 1
  • 2 weeks later...
Subaru Nut wrote:
"The other problem they have, is occasionally forgetting the time when starting the engine, which I have fixed by adding a couple of parts.
The 2 I have modified and installed in my cars have been flawless for a good while now."
Mine does that! How do I go about to fix that? Its quick to set it but irritating.
Edited by Adam K
Thanks for the offer but it is not worth the effort for me. Some day when I sell it the new owner can have the clock fixed if they want.
  • 1 year later...
