Ashwell Posted March 2, 2016 Share Posted March 2, 2016 So once again i have a problem with the loyale. So here it is, I have had both front axle nuts come loose. and i tighten them down and eveything seems good. exept that i will give it gas and then a huge thunk and rpms shoot up and hear a grinding noise. and i will put the axle nut on as tight as physically possible then it will do the same thing. Then it will work again. it has happened on both sides now. And im nervious to drive it far because the axle nuyt will stay tight but the thunk/grinding will happen randomly. i think its the hubs just let me know what you guys think, thanks! any response would be greatly appreciated! thanks! Link to comment Share on other sites More sharing options...
wagonist Posted March 2, 2016 Share Posted March 2, 2016 How can your nuts be coming undone if the split pin is inserted? If you've already stripped something, then you'll need to replace some parts Link to comment Share on other sites More sharing options...
Len Dawg Posted March 3, 2016 Share Posted March 3, 2016 Did you changes axles? Did you change hubs/rotorss? Are they the correct ones? We need a little more info... I'm guessing the the axle is spinning in side the rotor/hub... Link to comment Share on other sites More sharing options...
DaveT Posted March 3, 2016 Share Posted March 3, 2016 The torque from the axles is supposed to be transmitted to the hubs by the splines on both parts. If one is spinning, they are stripped. One or both may be stripped if they were both loose. The nuts cannot hold that much power back. The cotter pins cannot hold that much power back.With good axles and hubs, the nuts should be torqued to something around 150 Ft Lbs, and the cotter pin inserted to prevent loosening from vibration, etc. This is not a common failure, if the parts are assembled and tightened correctly. 2 Link to comment Share on other sites More sharing options...
harleywestcoast Posted March 12, 2016 Share Posted March 12, 2016 In the process of dealing with this myself on my 84 gl. road trip over the moutains. grinding sound, wont drive in 2wd. switch into four and drive home. rip apart hub axle assembly, hub stripped. order one from colorado. replace. use same cv axle ( 3 months old ). road trip again. same problem. have yet to rip it apart. any thoughts ? I may have needed to replace my cv axle again to have fresh splines. Link to comment Share on other sites More sharing options...
DaveT Posted March 12, 2016 Share Posted March 12, 2016 It wouldn't surprise me if the splines were damaged on both parts during the original problem Check the cone washer, the spring washer were installed correctly, and in good condition. Also, not a bad idea to double check the tightness after a drive or 2 after you reassemble it. Link to comment Share on other sites More sharing options...
harleywestcoast Posted March 12, 2016 Share Posted March 12, 2016 replaced both cv axles, the side that stripped was the first one i replaced, probably six months ago. spring washer? there is the cone washer and a regular large washer that fits between the castle nut and the cone washer. Link to comment Share on other sites More sharing options...
DaveT Posted March 12, 2016 Share Posted March 12, 2016 The cone washer is thick, and has a split / slit. The spring washer goes on next, and the concave side toward the hub. The concave / convex is subtle, so look closely. If you really have a flat washer, that might be part of the problem. Link to comment Share on other sites More sharing options...
Dee2 Posted March 13, 2016 Share Posted March 13, 2016 (edited) Quote I have had both front axle nuts come loose. and i tighten them down and eveything seems good. Axle nuts require a cotter pin to keep them from coming loose. Sounds like the pins are missing. If the castle nuts came loose while driving, chances are parts got damaged and will need to be replaced. Disassembly and inspection are, unfortunately, required. Edited March 13, 2016 by Dee2 Link to comment Share on other sites More sharing options...
D3F0 Posted March 15, 2016 Share Posted March 15, 2016 Also the axles are pressed into the fonts if everything came loose it could of ruined the fit and they are no longer able to be pressed in to keep everything from fitting together nicely. If i were you i would just source the parts to 5x100 swap its a much better design. Axles bolt right in and there is no way to strip the hub with the newer hubs. Link to comment Share on other sites More sharing options...
