Subarule Posted March 3, 2016 Share Posted March 3, 2016 Does this when I shut the engine off, altho' not 100% of the time. What does the dieseling (if that's what it's called) mean? It's annoying and probably not good. Non SPFI '86 GL, 5-speed. Link to comment Share on other sites More sharing options...
subnz Posted March 3, 2016 Share Posted March 3, 2016 (edited) hot spots ie carbon build up (oil consumption) glowing causing pre-ignition dieseling (run on) as well as a faulty carb / too much fuel (too high idling speed) helping to cause this and possibly incorrect ignition timing. also the use of low octane fuel in a high compression engine can cause this too. Edited March 3, 2016 by subnz Link to comment Share on other sites More sharing options...
Dee2 Posted March 3, 2016 Share Posted March 3, 2016 Is this a new problem ? Was anything recently done before the problem began ? A little background can help define the problem source. Link to comment Share on other sites More sharing options...
firehawk618 Posted March 4, 2016 Share Posted March 4, 2016 (edited) "subnz" hit it exactly right.If you don't want to fool around with fixing it you could just get in the habit of killing the car with the clutch then turn the key off.I mean, by all means you should fix it but being a 30 year old car I could see the hesitation in putting money into it.Checking the timing and adjusting the carb / installing correct idle jet isn't very expensive though.If you have heavy carbon build up there's a few things you can try but the right way is to pull the heads and clean the valves / piston tops. Edited March 4, 2016 by firehawk618 Link to comment Share on other sites More sharing options...
Subarule Posted March 4, 2016 Author Share Posted March 4, 2016 No. it's not a new problem. I'm pretty sure the carb needs adjusting. I don't work on cars so if there is someone in SW Washington that can fix this for I'd appreciate it. I can pay a bit. If I had the money I'd pour it into the Sube. Get the AC going again, put on new struts, replace the valve cover gaskets, re-do the front end (pretty minor stuff), and replace the headliner. Link to comment Share on other sites More sharing options...
DaveT Posted March 4, 2016 Share Posted March 4, 2016 Wasn't there an anti run on solenoid on some of the carburetor versions? Link to comment Share on other sites More sharing options...
subnz Posted March 4, 2016 Share Posted March 4, 2016 (edited) yep the original hitach that would have been fitted had this Edited March 4, 2016 by subnz Link to comment Share on other sites More sharing options...
firehawk618 Posted March 5, 2016 Share Posted March 5, 2016 Wasn't there an anti run on solenoid on some of the carburetor versions? I've heard some Webers also have the fuel cut off solenoid but I have no idea which ones do. I haven't come across a 32/36 that does. Link to comment Share on other sites More sharing options...
jonas Posted March 5, 2016 Share Posted March 5, 2016 With out the cut off solenoid it will always do it. It's just a matter of tuning (timing + carb tuning) to keep it at a minimum. My 2 webered '85 and ' 84 do it but rarely. Link to comment Share on other sites More sharing options...
Dee2 Posted March 5, 2016 Share Posted March 5, 2016 First thing I would do is run some higher octane fuel for a while to see if the problem is being caused by cheapo gas. You might solve your problem by better fuel. Link to comment Share on other sites More sharing options...
Uncle Ed Posted March 5, 2016 Share Posted March 5, 2016 Here you go. I hope this helps. Weber DGEV 32/36: http://www.carburetion.com/Products/ProductDetails.aspx?part=43928.060 Ed Link to comment Share on other sites More sharing options...
Subarule Posted March 7, 2016 Author Share Posted March 7, 2016 Here you go. I hope this helps. Weber DGEV 32/36: http://www.carburetion.com/Products/ProductDetails.aspx?part=43928.060 Ed Thank you. I bookmarked that page. Not cheap, are they? Where does that gizmo fit on? Link to comment Share on other sites More sharing options...
