2002 Impreza RS low compression issues
I have a few questions regarding my 2002 Impreza 2.5RS. It's having some starting issues. Sometimes it will start immediately, some times it will hesitate on starting, and other times it will just crank without actually starting. Every time it does not start, it sounds like a rifle has been shot. Here's whats been done recently: I've changed wires, both cylinder head cover gaskets (including the 4 spark plug boot gaskets), the timing has been checked (no belt/pump needed), and I've changed the crankshaft sensor. Earlier the car started like normal, but when shut off and I tried to start it again, it misfired and didn't start.
Today, I went to the shop that the car is sitting in now, and we checked the compression for the pistons. Here's what we got:
Cylinder 1: 60 PSI
Cylinder 2: 135 PSI
Cylinder 3: 30 PSI
Cylinder 4: 120 PSI
My mechanic seems to think that it is the camshaft, and that makes sense, since it is just the 2 passenger cylinders. However, he is not sure, and I want this done as quickly as possible.
So my main questions are: Has anyone experienced this before? Are there any ideas that someone has? Is any other information needed?
Thank you for taking your time reading this and for any feedback.
Edited by Muffinland
you have an issue with the passanger cylinder head. I doubt it's the camshaft. It's gotta be leaking compression. 60 PSI is barely enough compression to make a cylinder fire enough to support itself..
You believe it's the actual cylinder head itself?
If those numbers are right it has jumped timing. Backfire makes sense if it has bent valves.
Need to do a leak-down test.
This is originally what I thought was happening, but all of the timing marks were where they should be. All the teeth on the belt are also in fine condition. Is there another way that the valves could've been damaged?
Lots of things that could have happened.
Previous owner could have installed the belt wrong and bent the valves.
If it's been running rich for a long time it cluld have severaly worn piston rings.
Either way, leakdown test will tell.
If you want to confirm, pull the passenger side head and check the valves and cylinder walls.
