Fatenarr Posted March 11, 2016 Share Posted March 11, 2016 Has anyone replaced their oil separator plate? I will be pulling the motor and servicing the clutch and separator plate but I'm not sure if the new metal oil separator plate just bolts on and that's it or if there's gaskets, o-rings, or sealant involved in installing the new one? Thanks Link to comment Share on other sites More sharing options...
ocei77 Posted March 11, 2016 Share Posted March 11, 2016 Get the new allen type bolts, bought separately. Might as well reseal the access plate on the opposite side. Sealant alone will suffice for both. O. Link to comment Share on other sites More sharing options...
Fatenarr Posted March 11, 2016 Author Share Posted March 11, 2016 I found a plate on eBay that comes with screws. And are you referring to the wrist pin access plate o-ring on the opposite side? Link to comment Share on other sites More sharing options...
ocei77 Posted March 12, 2016 Share Posted March 12, 2016 yes. Can be sealed with only sealant. If the o ring is in once piece, reuse it and put sealant on cover. O. Link to comment Share on other sites More sharing options...
