A_racing_driver Posted March 14, 2016 Share Posted March 14, 2016 (edited) So i found a 5spd transmission for a 1997 sti wagon will it work in a 1993 wrx sedan? one will it bolt up and two is the gear ratios the same? Edited March 14, 2016 by A_racing_driver Link to comment Share on other sites More sharing options...
AdventureSubaru Posted March 14, 2016 Share Posted March 14, 2016 There's no such thing as a 97 STI or a 93 WRX. (at least here in the states anyway.)They both came later. Both Imprezas I'm assuming though... 97 transmission will bolt up to a 93 motor. Final drive ratio of the trans needs to match the rear diff. Get the trans codes off the bellhousing to check each one. Generally if equipped with EJ18 or Ej22 it would be 3.90 and if EJ25 it would be 4.11 Link to comment Share on other sites More sharing options...
A_racing_driver Posted March 14, 2016 Author Share Posted March 14, 2016 There's no such thing as a 97 STI or a 93 WRX. (at least here in the states anyway.)They both came later. Both Imprezas I'm assuming though... 97 transmission will bolt up to a 93 motor. Final drive ratio of the trans needs to match the rear diff. Get the trans codes off the bellhousing to check each one. Generally if equipped with EJ18 or Ej22 it would be 3.90 and if EJ25 it would be 4.11 They are imported form japan Link to comment Share on other sites More sharing options...
