garner Posted June 3, 2004 Share Posted June 3, 2004 Ok EA82T owners, help me out here. What happens if you unplug the Boost and Vacuum switches (mounted to the passenger side strut tower)? Will your car start? Anyone know if these ar normally open or normally closed switches? Anyone want to be a test subject for me? Try multiple combinations including both diconnected? I'm trying to troubleshoot my fuel injection system and have fuel pressure and good wiring (as far as I know) but I'm not getting injector pulse. I had assumed the boost and vacuum switches would no tprevent the motor from starting but now I wonder..... garner Link to comment Share on other sites More sharing options...
All_talk Posted June 3, 2004 Share Posted June 3, 2004 Look here: http://www.ultimatesubaru.org/forum/showthread.php?t=14610&highlight=hot+wire+fuel Gary Link to comment Share on other sites More sharing options...
garner Posted June 3, 2004 Author Share Posted June 3, 2004 Thanks Gary, I've read that. Interesting but to me it asks more questions than it answers. We are on the same quest, to understand the way in which the boost switch works. For me at this point I really just need to know if it's a N/O or an N/C switch. I had assumed that the Boost switch was a sort of failsafe that would prevent my motor from blowing up, now I wonder if it will prevent my motor from starting. It seems to be tied into the injector pulse and I assume that the fuel cut its at the injectors not the pump. There I go assuming again..... So, have you made any progess in understanding the workings of the boost switch and fuel cut? garner Link to comment Share on other sites More sharing options...
All_talk Posted June 3, 2004 Share Posted June 3, 2004 I’m still running stock boost so I haven’t tackled it yet, if I get a chance tonight I’ll check the continuity of the switches. Gary Link to comment Share on other sites More sharing options...
garner Posted June 3, 2004 Author Share Posted June 3, 2004 if I get a chance tonight I’ll check the continuity of the switches. Gary that would be a huge help to me, thanks garner Link to comment Share on other sites More sharing options...
mudrat79 Posted June 3, 2004 Share Posted June 3, 2004 Hi-Jacking this Thread for a sec..... Garner.....Call me ASAP......About Auto-Cross this Weekend......At Valley River Also, I may be able to steer you in your Quest.... Or Come by...I have a Running Turbo Car in the driveway.... Later, John Hi-Jacking ENDED................... Link to comment Share on other sites More sharing options...
All_talk Posted June 8, 2004 Share Posted June 8, 2004 We’ll I finally checked the switches (it was a crazy weekend, son’s graduation/family reunion kind of thing), sorry for the delay. The top switch (single vac/pressure line) is the one for the boost gauge/”heavy load” signal. Its normal open and trips just above 0psi. The lower one appears to be the over boost/duty solenoid, the contacts are normally closed. I’m not sure exactly how this thing works, I could not get the switch to trip no mater how I pressured it, I think the contacts may just be for the coil in the duty solenoid. I’m going to have to do a bit more testing to figure out how this thing works. Gary Link to comment Share on other sites More sharing options...
garner Posted June 8, 2004 Author Share Posted June 8, 2004 thank Gary, Interesting that the boost/fuel cut switch is normally closed. That one may be causin me some trouble. I was at a friends shop who has a running ea82t and when I disconected that switch nothing happened (It didn't die) I aught to get those switches and plug them in just to be sure. I think it is worth while to understand the fuel cut/ boost switch so that we can perhaps bypass or modify it for mor eboost and mor efun! thanks again garner Link to comment Share on other sites More sharing options...
MilesFox Posted June 8, 2004 Share Posted June 8, 2004 i have bypassed the hoses to the switches, looping the vac hose from the turbo to the wastegate, car runs the same, looped it like the 86 turbo xt had it stock without the switches. Link to comment Share on other sites More sharing options...
