Subimp91 Posted March 16, 2016 Share Posted March 16, 2016 Hey. having some problems with my impreza gt 97. EJ20G. Tested the car yester day after i changed the clutch. To day i were just changing the steering fluid. After that the car wont start. The car have been hard to start some times before. but have always started. Now it wont start. i can hear the fuel pump running. Installed new spark plugs, New coil and plug wires. The compression is good. When i pull out the spark plugs they are wet from gasoline. When i pull of the plug wires, sparks shoot out. When i connect a Ignision lamp??? not sure what its named on english. Its the thing that show your spark plug timing/ flashing light on the crank. It does not flash. If i keep cranking the engine about 15 sec. the engine almost starts, and the ignision lamp flashes a few times. So i guess the problem have something to do with that. I have read troublecodes. Getting Code 24 and 32. Been told that if the taco meter move when i crank the engine, the crank sensor is in working order. Were do i go from here??? Please help Quote Link to comment Share on other sites More sharing options...
DaveT Posted March 16, 2016 Share Posted March 16, 2016 If the plugs are wet with gas, could it just be flooded? About 1 time every 8 years I've had one of my cars goof up and flood. Hold gas pedal on the floor while cranking. For kind of a while. And it clears. I don't know for sure with the newer models. 1 Quote Link to comment Share on other sites More sharing options...
Subimp91 Posted March 16, 2016 Author Share Posted March 16, 2016 I will try that tomorrow. But I'm pretty sure it won't help. Because when I crank the engine it doesn't have spark. At least that's what the ignition lamp is telling me. But then again if I pull one spark lead of, the Sparks shoot out of the coil. But thanks for the tip. Really need help on this one???? Quote Link to comment Share on other sites More sharing options...
