I'm going to say that it probably needed a new flywheel if you replaced the clutch and resurfaced the flywheel. If the flywheel had gotten too hot, resurfacing it only hides the problem. I've run into this issue a couple times on the pull type clutches and have had it bite me when I didn't replace them.
Edited by Caboobaroo
This. overheating makes hot spots, hot spots change the metallurgy visibbly, changing the color and hardness with significant depth. Resurfacing smooths the surface but as soon as you warm it up a few times (like a month of driving) those hard spots show proud again causing vibration and chatter.
Did you replace the clutch or pressure plate? If the FW was bad enough to justify cutting it, the PP would be just as bad. Cutting the PP has the same problem as cutting the FW.
