soopsoop Posted March 19, 2016 Share Posted March 19, 2016 i hooked everything up like i was suppose to, except the wire for the power antenna, why did they call it that? should have been called antenna amp wire it would have made it a lot easier to figure out. any way hooked that wire bto the 12v switched wire and i get lots of stations now thank God for usmb i read through the different topics and found others with the same problem. 1 Link to comment Share on other sites More sharing options...
gbhrps Posted March 20, 2016 Share Posted March 20, 2016 soopsoop, They called it the power antenna wire because on the generations of subies that ran power antennas, it was needed to raise and lower them. My 1997 OBW, LTD, for instance, had a power antenna from the factory. And it makes it easier for us to answer your questions if you add the year and model of your car to your signature. Link to comment Share on other sites More sharing options...
