any chance there is corrosion at the fuse location to disable AWD? that would be too simple...
He'd have to have a fuse in there already and it'd be the other way around i.e. FWD being on all the time with fuse in, then AWD coming on out of the blue.
You can isolate the wire that controls the solenoid valve that controls the AWD, and try hooking it to +12V and seeing if you get any AWD out of it.
(2003 and younger, +12V disables the AWD, 2004+ no voltage disables it).
Pain in the butt to do, when there's no symptoms other than loss of rear drive there's not a lot to check without opening it up.
Are you sure it was FWD only?
