Go to opposedforces.com and drill down to your year/model and look under Train>>Differntial (trans) for some info.
XS is 4.44 FD ratio and should be the same for '03-'08...but the site shows a different p/n for the '03-'04 model. The XS
And use car-parts.com for interchange.
The '04-'05 5-speeds used a 4.44 too, IIRC.
The OB XT had a 4.44, too...not 100% sure on the years.
The XS and XT models have  rear axle limited slip differential...not on the X.
Td
Edited by wtdash
Subaru uses a fluid type LSD. No clutches. Friction modifiers do no good.
What symptoms are you having? Is it jerking and lurching in turns after it warms up?
How many miles on the car?
Edited by Fairtax4me
Sounds more like the center diff in the trans.
Rear diffs on these rarely go bad, and when the limited slip fails it tends to fail open so it just acts like a regular diff. A ring gear problem is possible, and that should cause a bunch of metal in the fluid.
Center diff failure is more common and the center diff often fails to a locked position. Again, no clutches, just a slightly different design than the limited slip unit in the rear diff. Mismatched tire sizes, or greatly worn tires on one axle or one side vs new tires on the other side will cause damage to the center diff. Do all 4 tires match in brand, model, size, and tread depth?
  • Like 1
on yours, not sure - the info should be in the manual near the section on using the 'donut' spare tire.
you should be able to find a spare fuse, inside the cover of the under-hood fuse box in front to the left (US driver's) side strut tower. Any fuse will work - and it can be used as a normal spare afterwards. The slot to put it in is either in that same fuse box or, on newer cars, it may be a slot in the cabin fuse panel near your left knee.
