Zebbadiesel Posted April 2, 2016 Share Posted April 2, 2016 1- would an 8x70 or some other 8 lug rim fit? I know it's not intended just curious. 2- if I put the ea82 5spd what do I need to do the 5 lug swap? The non turbo, because to my understanding it's geared better, question mark? Quote Link to comment Share on other sites More sharing options...
firehawk618 Posted April 5, 2016 Share Posted April 5, 2016 (edited) I'll take a stab at this.Question #1 8x70 8 lug wheel? What would that come on? Seems like if it were a 70mm bolt circle then the lugs would all be touching each other? If you could find 8 lug on 140mm bolt circle then I don't see why they couldn't be made to fit pretty easy however I don't believe there to ever be a wheel produced with that bolt circle.Question #2 Is English your first language because I can't comprehend what you are asking no matter how many times I read your question. Edited April 5, 2016 by firehawk618 Quote Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 5, 2016 Share Posted April 5, 2016 1- would an 8x70 or some other 8 lug rim fit? I know it's not intended just curious. 2- if I put the ea82 5spd what do I need to do the 5 lug swap? The non turbo, because to my understanding it's geared better, question mark? 1. No only other lug pattern that would work with stock hubs is 6x5.5 by either drilling 4 more holes in the hubs or 2 in the rims. 2. There are plenty of write ups for 5 lug swaps. Type ea82 5 lug swap into google. Transmission depends on how your rig is setup and what you plan on doing with it. Quote Link to comment Share on other sites More sharing options...
Subaru_dude Posted April 5, 2016 Share Posted April 5, 2016 No, you don't have to do a 5 lug swap if you do a d/r swap. Just incase that's what you were asking... Quote Link to comment Share on other sites More sharing options...
