P0420, traction light, cruise light
These things happened after running over a small  tree branch with my 09 Impreza. Pressing control buttons had no effect.  After a day's worth of stop/restarts, the problem disappeared. I cleared a P0420, and none of the lights came back. I thought maybe a wiring issue--your thoughts?
Possible you damaged one of the catalytic converters, or one of the oxygen sensors.
On newer Subarus when the check engine light comes on, you also get a flashing cruise control light because the cruise control is disabled when the CEL is on. Traction control may also be disabled. Sometimes the traction control light may come on due to a wheel slipping or losing contact with the ground if something is run over.
Systems often disable with a check engine light, so the P0420 caused the VDC and cruise to disable.
Once that code disappeared those systems resumed nominal ops.
why the P0420 code was set might be the main question.  That's weird.
