88 Justy 1.2 carb engine setting ignition timing
Hi everyone,
A friend of my daughters just got an 88 Justy 1.2, standard trans,  with carburetor.  I will be helping him change the timing belt. That looks pretty straightforward.
My question is about setting ignition timing. I found a spec of 5 degrees BTDC.
Vacuum advance hose disconnected?
I saw some references (for a 92) to connecting the test connector under the dash, I'm guessing that is for fuel injected engine. Does this apply to the 88?
Any tips/advice/suggestions?
Thanks!
Gene
Hi everyone,
Thanks!
Gene
On a vacuum advanced distributor just warm the rig up, make sure your idle speed is set, unplug and cap the vacuum hose and set timing.
