PoorManzImpreza Posted June 5, 2004 Share Posted June 5, 2004 If so I'll take pics tomorrow swap took exactly one evening and the next day..I only wish it was in my car! details ea82 engine crossmember adjusted holes ea82 coil and sensor harness (oil pressure, temp etc) ej fwd 5speed tranny ej DOJ on ea82 shaft and outer ea front tranny crossmember adjusted to fit ;-) ej power steering lines mated to ea rack ac compressor on block but inactive carb looks like more modern ea82 hitachi (not the crappy feedback and emission crippled one you guys get ;-)..looks simpler and a bit bigger even though air filter opening is the same size... ea82 fuel pump and lines, carb fed with full pressure no return line although I think that isn't wise... car burns rubber in 4th...and the power is on from way down low right up beyond red line.. engine came out of a '90 or '91 legacy DL and since there was a lonely carbed ea82 engine sitting all forlorn and lonely I took it and will give it a good home anyone got an ea82 flywheel they wanna send on extended vacation in the tropics? pics @ http://photos.yahoo.com/xionprince/ Link to comment Share on other sites More sharing options...
Beavis Posted June 5, 2004 Share Posted June 5, 2004 I want to see it. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 20, 2004 Author Share Posted June 20, 2004 bump pics added guys Link to comment Share on other sites More sharing options...
WJM Posted June 20, 2004 Share Posted June 20, 2004 those things had carbs on them? Edit: And a distributor???????????? Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 20, 2004 Author Share Posted June 20, 2004 yup lol you like my friends paint job? btw this was a true ghetto swap engine isn't *quite* sitting the way it should lol Link to comment Share on other sites More sharing options...
WJM Posted June 20, 2004 Share Posted June 20, 2004 Yeah, I noticed it was not in there stright....a little... Link to comment Share on other sites More sharing options...
