rmax91 Posted April 9, 2016 Share Posted April 9, 2016 am i able to put a 98 Subaru Forester automatic gearbox into a 97 Subaru Forester? 1 Link to comment Share on other sites More sharing options...
ocei77 Posted April 9, 2016 Share Posted April 9, 2016 As far as I can see there was no 97 Forester, not even in Europe. However, the Forester is just a wagon built on an Impreza flatform and I would start there. There are too many options for me to even think about answering. If you will go to a previous post started by grossgary on opposed forces website, there is a link there to this site that will guide you that should answer your question. Find your engine and drive configuration and click on the part number. Then click on usage info, this will give all the models that use the same part. O. Link to comment Share on other sites More sharing options...
rmax91 Posted April 9, 2016 Author Share Posted April 9, 2016 my forester is a 97 its a japanese import the 1st year they started the production of the forester was 97 for japan only and 98 was for the american market and europe Link to comment Share on other sites More sharing options...
lmdew Posted April 9, 2016 Share Posted April 9, 2016 As long as the front and rear Diff ratios are the same you should be fine. Link to comment Share on other sites More sharing options...
wtdash Posted April 10, 2016 Share Posted April 10, 2016 (edited) ^+1 Hi, Do the Kiwis have an 'interchange' system? We have car-part.com (one example) that has all USED vehicles and will show parts that interchange. I'd also compare the trans ID label on the bell housing...starts w/a TZ for Automatics, in USA...also on the VIN plate by the driver's (passengers for NZ?) strut tower under the hood in USA. Like this (TY is manual/5-speed): GL, TD Edited April 10, 2016 by wtdash Link to comment Share on other sites More sharing options...
