Rear top hats (top strut mounts?) will need swapped to your '93 - (same # of bolts on Forester- but different pattern).
There's also possibly an issue w/the tapered springs, and I'm not sure if the '93's are tapered or not, which would require the Forester's springs to match to fit the top hats....I know it's been  done.
You can also 'ghetto' it by drilling out a hole to match the Forester top hats ...look that up online if interested. I did than on my '90 wagon and it worked fine - thru 3 different suspension setups: OB>>Forester>>WRX
TD
Edited by wtdash
