Kharl Posted April 13, 2016 Share Posted April 13, 2016 Hi guys!This is a 93 FWD Automatic Legacyi had several years with the shift lock system not working properly, some times unlock when i depress the brake pedal; often does nothing and then i have to manually unlock it (pressing the button)but now, i just decide... i wan tot pursuit the problem and fix it! (with your help, of course)i just disassembled the shift lock plastics.. and i used my multimeter to figure it out that there is no voltage at the solenoid when i press depress the break pedalso following back the chain.. i guess I should now test the solenoid relay.. am i right?Where can i locate it? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 13, 2016 Share Posted April 13, 2016 I think some people have replaced the switch at the brake pedal - or a plastic 'button' that contacts it. Link to comment Share on other sites More sharing options...
Kharl Posted May 20, 2016 Author Share Posted May 20, 2016 (edited) i checked that switch and the solenoid is fine too, i want to check the relay, how do i get access to it? Edited May 20, 2016 by Kharl Link to comment Share on other sites More sharing options...
