superpoo93 Posted April 13, 2016 Share Posted April 13, 2016 (edited) I followed the 4WD bearing guide that 987687 submiited and created my own tool to press bearing sleeve in. Might be helpfull to those that are just discovering there awesome cars. Note: carefull not bang the double jack to far while removing the sleeve it may damage the builtin bearing stop surface. Used 3/4" x 12" allthread 3ea 3/4" nuts Edit: 2ea 7/8" 2-1/2 washers(used over size hole size to make small adjustments) 1ea 3/4"x 3" sq washer ( i used slotted) 1ea 1-1/4 pvc adapter(perfectly tapered to fit inside the sleeve) Edit: used 2ea 3/4" x 2-1/4 also on both ends Center bearing and tool a slowly tight and recheck centering. Then slowly tight inside nut and it just slips in. It will feel like it resisting, continue to tighten slowly.. Till full seats against bearing stop. I going to replace my other bearing soon, so think with some mods it can used to remove bearing as well. Edited April 14, 2016 by superpoo93 2 Link to comment Share on other sites More sharing options...
superpoo93 Posted April 13, 2016 Author Share Posted April 13, 2016 (edited) I forgot to show another pic of how the pvc adapter fit the the sleeve Edited April 13, 2016 by superpoo93 Link to comment Share on other sites More sharing options...
Rust Posted April 14, 2016 Share Posted April 14, 2016 1 Link to comment Share on other sites More sharing options...
superpoo93 Posted April 16, 2016 Author Share Posted April 16, 2016 On 4/14/2016 at 1:53 PM, Rust said: Thanks. Next time I'll post a video on You Tube Link to comment Share on other sites More sharing options...
