I was replacing the valve cover gasket on my 95 legacy and broke the bolt because I'm a dumbass. It's broken inside (not sticking out and not flush) and I can't find a replacement bolt nor can I find a part number online. I have a 2000 outback that's down for head gaskets. Can I use one from that?
If it's the middle bolt just put a rubber grommet in the valve cover and you can use just the two outer bolts to hold it on.
The rocker shaft assembly is easily removable and you can grab another end block from a junkyard car and get some spare cover bolts.
If no junkyards nearby look in the parts classifieds here.
Also pretty sure the timing covers use the same bolts as the valve cover.
