ChipFormica Posted April 30, 2016 Share Posted April 30, 2016 I have tried countless times to get my Impreza in programming mode. Turning key 10 times and NO horn honk. Tried opening door with key in and out, seatbelt on, foot on brake etc... Still will not enter programming mode. Any ideas? Link to comment Share on other sites More sharing options...
Legback0203 Posted April 30, 2016 Share Posted April 30, 2016 If it's the same as a third gen outback then make sure you unlock then open close door before the other stuff. Other than that just keep trying it. Took me a ton of tries with mine Link to comment Share on other sites More sharing options...
ChipFormica Posted April 30, 2016 Author Share Posted April 30, 2016 Thanks. I did unlock. Have tried half a ton of tries. Will try the other half today. Link to comment Share on other sites More sharing options...
beat2def Posted April 30, 2016 Share Posted April 30, 2016 I can get the car to beep once going through the whole 10 time +opening and closing driver's door and three times at the end of the"programming," but I can't get the horn to beep twice (the in betweenstep) when I push the key fob to program the remote. The battery isbrand new and the + is lined up with where it's supposed to go. When Ido push a button there is no "beep twice", but when I take the keys outof the ignition there is a "beep three times". The remote doesn'twork. When I push a button the red light on the remote stays on longerthan I feel like it should. Why is it not programming? Whywill it beep the one time with the "10 turns" and three times when Itake the key out, but it won't beep twice to program my remote? Could it be that at one time, I believe, this key was programmed to a Subaru Outback 02 instead of my Subaru Forester 03? I'm using the "orange and blue" key fob for my Subaru Forester 03. Link to comment Share on other sites More sharing options...
