Starlite Posted May 1, 2016 Share Posted May 1, 2016 Hello i having problems with my radio in my Legacy 3.0 2007. Today before i was checking the cable couplings on the radio it worked but sometimes went dead for a while and sudden it started again. The fan control unit works well but radio screen was black. Today i checked the cable coupling and started the car and radio was dead and wont start anymore. It started for a couple of seconds but went dead again. Is there anyone else having the same problem? Link to comment Share on other sites More sharing options...
Cougar Posted May 1, 2016 Share Posted May 1, 2016 I suggest you check the power input to the radio to make sure that is okay before blaming the radio itself. Link to comment Share on other sites More sharing options...
mikaleda Posted May 1, 2016 Share Posted May 1, 2016 I've heard of a few complaints in the outback forums about the circuit board on the back of the radio desoldering the pins. Do you have the HVAC/radio that are built together? Link to comment Share on other sites More sharing options...
Starlite Posted May 1, 2016 Author Share Posted May 1, 2016 Well now it's alive again, for now . HVAC/radio yes i belive so, http://i24.photobucket.com/albums/c43/Istvan_Sz/AUX4.jpg Not mine but the same model. Link to comment Share on other sites More sharing options...
mikaleda Posted May 1, 2016 Share Posted May 1, 2016 http://www.subaruoutback.org/forums/80-electrical-electronics/23909-08-o-b-radio-hvac-control-lighting-prob.html#/forumsite/20514/topics/23909?page=1 This might help Link to comment Share on other sites More sharing options...
Cougar Posted May 1, 2016 Share Posted May 1, 2016 Good info from "mikaleda". I would speculate that is exactly what is causing the intermittent problem to the radio. Reflowing the solder connections will most likely fix the issue. 1 Link to comment Share on other sites More sharing options...
Bushwick Posted May 2, 2016 Share Posted May 2, 2016 I wouldn't just "reflow" the solder as it'll just happen again. Go to Radio Shack and buy a 45-60 watt soldering iron. No need to get fancy unless you plan to solder a bunch of stuff in the future. A straight soldering will suffice. They sell braided copper as well. It comes in a white disc and the copper is spooled inside. The rubber disc helps to protect the copper. Also, buy a reel of thinnest lead-free solder. I say thinnest as it's easier to work with and doesn't require as much prolonged heat to flow it. Remove radio from car and power, and get access to the pins in question. Pull a section of the braided copper out, and let it touch the solder on the pins or PCB, etc. Heat it up. The copper will act like a wick and pull the solder into it. Just keep using fresh copper until it's all off. Then, go back and lay fresh solder down. If new solder mixes with old, it won't hurt anything. Radio Shack is fairly decent, and hopefully it holds longer than whatever the factory used. Do NOT allow fresh solder to bridge connections it's not supposed to, or you'll end with a short. Link to comment Share on other sites More sharing options...
Starlite Posted May 29, 2017 Author Share Posted May 29, 2017 Well still having this problem. Have tryed to reflow the solder but it did not help much https://youtu.be/K1WlekKDCDM Link to comment Share on other sites More sharing options...
