Mack Truck Posted May 15, 2016 Share Posted May 15, 2016 Some time ago i started a 4in lift kit from Anderson, but also wanted to Improve my shocks and struts. I followed Loyale 07's suggestions for struts and springs. however the front springs i got the new Subaru Struts for the front and the 94 Ford Tempo springs as suggested. however the oiriginal springs have 8 1/2 in tall and the Ford Springs are 15 inches tall. i see no way to compress them enough to get them the Subaru struts. I did compare them to the NAPA Ford Tempo springs and they are the same. Any suggestions of what to do next to make these work? Regarding the rear ones they will make my car 2 in higher than stock. will the 4in lift kit and this strut change (Honda Accura springs, and Toyota Forerunner Struts/shocks) make my GL like a 6in lift in the rear? Link to comment Share on other sites More sharing options...
elRayRay Posted May 19, 2016 Share Posted May 19, 2016 Regarding the rear ones they will make my car 2 in higher than stock. will the 4in lift kit and this strut change (Honda Accura springs, and Toyota Forerunner Struts/shocks) make my GL like a 6in lift in the rear? This is my understanding, though I would like to hear it from someone else. Maybe ask in the Off road forum? Link to comment Share on other sites More sharing options...
Mack Truck Posted May 22, 2016 Author Share Posted May 22, 2016 oh ok and thanks ill copy this post to the Off Road side and see what they say.... Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 22, 2016 Share Posted May 22, 2016 I had to cut 3 coils off a set of tempo springs to get them to fit. What car is this? If its a 1982 then don't get struts for the rear they have a torsion bar. It will make the rear extremely stiff. If you meant ea82 then you will be fine replacing the struts. Link to comment Share on other sites More sharing options...
Stihlman Posted May 22, 2016 Share Posted May 22, 2016 Question if you have the taller springs does that eliminate the need for a spacer in the strut tower? Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 22, 2016 Share Posted May 22, 2016 Question if you have the taller springs does that eliminate the need for a spacer in the strut tower? Depends on how much you want to lift it and how often you want to change cv's. Link to comment Share on other sites More sharing options...
Stihlman Posted May 22, 2016 Share Posted May 22, 2016 Depends on how much you want to lift it and how often you want to change cv's.if you used spacers everywhere else you usually would,just not on the struts? Because of the tall springs? Link to comment Share on other sites More sharing options...
