Hey guys, Over the weekend I finally got around to putting the rest of the Franken motor back together, and finally got the the new lightweight Exedy flywheel on with a new Exedy Stage 1 clutch and pressure plate. Now I know I can set the clutch up the same as it was when I originally got the car, but the owner(My Best Friend), didn't like how it released so far up in the travel. So how can I adjust it so it releases lower, and how do I make sure I did it right?
Specs:
1995 Impreza L Wagon
5 speed
Cable clutch
new clutch(stage 1)
new flywheel(light weight)
2.5L Block with 2.2L heads
DOES NOT have hill hold
If you need any more info, I would be happy to add that as well.
Thank you in advanced!
I'm going to assume that it had a cable operated clutch cable? If you want the clutch to grab off of the floor you would usually do it by the book. Loosen the clutch cable on the fork until there's play and tighten it up until there's about 1/8 (don't quote this I believe that's the tolerance) play on the fork.
  • Like 1
