angerthis Posted May 19, 2016 Share Posted May 19, 2016 Okay I know this question that's probably came up a thousand times but I am brain farting I can't remember when installing the oil pump the bigger Gear with the letter B on it dose it go in or out facing the engine Link to comment Share on other sites More sharing options...
TomRhere Posted May 19, 2016 Share Posted May 19, 2016 Faces out. Link to comment Share on other sites More sharing options...
jono Posted May 19, 2016 Share Posted May 19, 2016 out as said above, I remember it as B faces Block 1 Link to comment Share on other sites More sharing options...
angerthis Posted May 19, 2016 Author Share Posted May 19, 2016 out as said above, I remember it as B faces Block Your answer is kind of contradicted itself you say out but that wouldn't be facing the block so does point out with the letter b towards the radiator Link to comment Share on other sites More sharing options...
TomRhere Posted May 19, 2016 Share Posted May 19, 2016 never thought of it that way Jono. Link to comment Share on other sites More sharing options...
TomRhere Posted May 19, 2016 Share Posted May 19, 2016 Your answer is kind of contradicted itself you say out but that wouldn't be facing the block so does point out with the letter b towards the radiator Faces "out" as you're looking at the backside of the pump. Faces "in" would be towards the pump, away from you Link to comment Share on other sites More sharing options...
Dee2 Posted May 20, 2016 Share Posted May 20, 2016 Maybe this will clarify http://www.dirally.com/forums/showthread.php?2726-ea82-Oil-Pump-R-amp-R Link to comment Share on other sites More sharing options...
idosubaru Posted May 20, 2016 Share Posted May 20, 2016 That side faces the installer as seen in a mirror while looking over his shoulder reaching around the engine stand from the back of the engine. Holy smokes need a clear reference: does B face the engine or radiator? 2 Link to comment Share on other sites More sharing options...
jono Posted May 20, 2016 Share Posted May 20, 2016 (edited) Okay I know this question that's probably came up a thousand times but I am brain farting I can't remember when installing the oil pump the bigger Gear with the letter B on it dose it go in or out facing the engine see the little bit at the end of your post ? I used an expression typed by your fingers to help you work it out - out facing the engine sort of contradicts my thinking, so I had to adapt to yours to give an answer you would understand - hOK? B facing block is easier to recall which way is out - depending on how you look at things angerthis, on 20 May 2016 - 09:37, said: Your answer is kind of contradicted itself you say out but that wouldn't be facing the block so does point out with the letter b towards the radiator Faces "out" as you're looking at the backside of the pump. Faces "in" would be towards the pump, away from you end quote quote start again, would be three weeks since I pulled an EA82 oil pump off and that is how I carefully noted things as I stashed the thing away - where I no not now ! Edited May 20, 2016 by jono Link to comment Share on other sites More sharing options...
