ferp420 Posted September 9, 2017 Share Posted September 9, 2017 On my loyale some one before it came to me had the check engine light rewirered to the altornator light it comes on then you turn the key on and goes off once running like its saposed to they took the wire off the check light and ran a second wire from the alternator light very easy to do and to get to on my freinds car it was a auto but now its a manual and someone wired in a relay to fix the nutral safty switch i dont have any idea how it was done but i know it can be done Link to comment Share on other sites More sharing options...
subpoop Posted January 13, 2019 Share Posted January 13, 2019 can you jumper the connector with a wire? Link to comment Share on other sites More sharing options...
FerGloyale Posted January 16, 2019 Share Posted January 16, 2019 On 9/9/2017 at 8:40 AM, ferp420 said: On my loyale some one before it came to me had the check engine light rewirered to the altornator light it comes on then you turn the key on and goes off once running like its saposed to they took the wire off the check light and ran a second wire from the alternator light very easy to do and to get to on my freinds car it was a auto but now its a manual and someone wired in a relay to fix the nutral safty switch i dont have any idea how it was done but i know it can be done it's not a "neutral safety switch" Neutral switch on MT subarus HAS NOTHING TO DO WITH STARTING And to the OP......If part 30 in the upper diagrahm is broken, you are going to get stuck in 4wd at some point. Possibly even stuck in 4 low. That is the 4wd shift collar and has several interlock pins inside to grab and let go of the lo range rod. Happens when the 4wd shift rod rotates while being pushed in/out. Plan on needing to replace that fork. Link to comment Share on other sites More sharing options...
el_freddo Posted January 16, 2019 Share Posted January 16, 2019 Good thread dig from 2016! Maybe they’re stuck on the side of the road somewhere with a jammed gearbox waiting for help? Cheers Bennie 1 Link to comment Share on other sites More sharing options...
FerGloyale Posted January 16, 2019 Share Posted January 16, 2019 3 hours ago, el_freddo said: Good thread dig from 2016! Maybe they’re stuck on the side of the road somewhere with a jammed gearbox waiting for help? Cheers Bennie dang it gotta remember to look at dates on these 1 Link to comment Share on other sites More sharing options...
