Fixme Posted May 20, 2016 Share Posted May 20, 2016 2001 AT Forester L today while driving I tried to put the car in reverse. It would not shift to reverse. Now the car is locked in P, the ignition key will turn, all dash instruments light up, brake lights do come on with pedal depressed, car will notstart. I can over ride P move shift to N, key will turn in ignition but car will not start Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 20, 2016 Share Posted May 20, 2016 (edited) hmmm...try locking and unlocking the car with the fob. also, try 'popping' the brake pedal - quick step-on/step-off - a coupla times. Edited May 20, 2016 by 1 Lucky Texan 1 Link to comment Share on other sites More sharing options...
mikaleda Posted May 20, 2016 Share Posted May 20, 2016 Sounds like a malfunction in the park lockout. Good suggestions from 1 lucky Texan. I would also suggest checking the wires and connections to the brake pedal switch even though the brake lights are working. 1 Link to comment Share on other sites More sharing options...
Fixme Posted May 20, 2016 Author Share Posted May 20, 2016 Thanks for the suggestions. I ran out of time and further diagnostic knowledge so I jumped the starter to get the car to a garage. Link to comment Share on other sites More sharing options...
Fixme Posted May 21, 2016 Author Share Posted May 21, 2016 hmmm...try locking and unlocking the car with the fob. also, try 'popping' the brake pedal - quick step-on/step-off - a coupla times. Sounds like a malfunction in the park lockout. Good suggestions from 1 lucky Texan. I would also suggest checking the wires and connections to the brake pedal switch even though the brake lights are working. Thanks for the suggestions. Turns out the issue was the shift cable broke. 1 Link to comment Share on other sites More sharing options...
