dp213 Posted May 20, 2016 Share Posted May 20, 2016 Should the oil pump on a 95 2.2 a gasket, or should I put a thin layer of sealer in it, or nothing? Link to comment Share on other sites More sharing options...
mikec03 Posted May 20, 2016 Share Posted May 20, 2016 According to the factory, you should use a gasket sealer goop. Search for best type or wait for other replies. However, when I did the oil pump on my 97 2.2 engine, I went to advanced auto and got one of their thin, paper like gaskets because I was afraid of getting some of the goop in the oil circulation system. It worked fine. Link to comment Share on other sites More sharing options...
ocei77 Posted May 20, 2016 Share Posted May 20, 2016 You don't use a gasket on the oil pump, just sealant. Your choice, I use anaerobic. O. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 20, 2016 Share Posted May 20, 2016 (edited) Anaerobic sealant. no gasket. http://beergarage.com/SubyOPump.aspx Edited May 20, 2016 by Fairtax4me Link to comment Share on other sites More sharing options...
idosubaru Posted May 21, 2016 Share Posted May 21, 2016 In addition to what they said There's an oring. Id tighten the backing plate screws too. The 95 oil pump is same as all the others. Get a free FSM they're readily available all over the Internet. I've got like 10 or 15, excellent resources. Link to comment Share on other sites More sharing options...
Bushwick Posted May 21, 2016 Share Posted May 21, 2016 Anaerobic is the ONLY sealant you should be using on an oil pump. It's designed for extremely flat surfaces w/o gaps. It'll seal in the absence of air (gasket surface only) but remain soft if it enters the oil. Unlike RTV which can/will break off and clog oil passages, anaerobic won't as it won't harden in open air. Yes, it costs $15 a tube, but it's a must, especially on rotor-style oil pumps. I used it on mine, and even installed a mechanical oil pressure gauge. On cold starts with 10w30, it's around 75-80 psi at idle. Once fully warm at idle, it's around 8-10 psi and I think reaches the 40-60 range when moving but I haven't been paying attention while moving to be honest. Anaerobic can be a PITA to break the seal on. If you end up having to pull the pump assembly again, and it's sticking like glue, put some propane pencil torch heat on it evenly, then tap it or carefully pry, it'll pull right apart. Link to comment Share on other sites More sharing options...
