WoodsWagon Posted June 6, 2004 Share Posted June 6, 2004 When you swap an EJ engine in and make an adapter plate to attach it to the EA82 transmission (manual, D/R), can you use the EJ flywheel and clutch or do you have to use the EA clutch and flywheel? I'd prefer to use the EJ clutch because it was meant to handle the power, and I just bought a cable clutch EJ22 car with this in mind for its future. If I can't use the clutch and flywheel, I might as well use the engine out of a trashed legacy (2wd auto) that my neighbor has. I'd have the engine out anyways, so i could helicoil the plug threads like it needs, and then just consider my legacy a $75 spare. Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 7, 2004 Author Share Posted June 7, 2004 Anyone? I searched, but didn't find an answer. Will the EJ flywheel and clutch fit? Link to comment Share on other sites More sharing options...
Dr. RX Posted June 7, 2004 Share Posted June 7, 2004 Why not e-mail that guy in Australia who put an EJ into a Hatchback. Link to comment Share on other sites More sharing options...
MilesFox Posted June 7, 2004 Share Posted June 7, 2004 cause he used an EA82 flywheel/clutch Link to comment Share on other sites More sharing options...
iluvdrt Posted June 7, 2004 Share Posted June 7, 2004 i think turbo magazing did a ej swap into an 90 legacy. it was a few issues ago. they did a complete write up. Link to comment Share on other sites More sharing options...
calebz Posted June 7, 2004 Share Posted June 7, 2004 EJ swap into a legacy?.. legacies come with an EJ.. not much of a tough swap:-p Link to comment Share on other sites More sharing options...
iluvdrt Posted June 7, 2004 Share Posted June 7, 2004 EJ swap into a legacy?.. legacies come with an EJ.. not much of a tough swap:-p i messed that up. it was a loyal wagon. Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 8, 2004 Author Share Posted June 8, 2004 sorry, I couldn't find the article. There is one on Autospeed.au but he used the EJ tranny. I need to know if the EJ flywheel and clutch will fit in the extra space provided by the adapter or if I would have to use the EA flywheel. Link to comment Share on other sites More sharing options...
Dr. RX Posted June 9, 2004 Share Posted June 9, 2004 Have you tried getting ahold of the guy in Australia, here is the link to his post on the board, http://www.ultimatesubaru.org/forum/showthread.php?t=17327 Link to comment Share on other sites More sharing options...
WoodsWagon Posted June 15, 2004 Author Share Posted June 15, 2004 Bump bumpity bump Link to comment Share on other sites More sharing options...
bushbasher Posted June 15, 2004 Share Posted June 15, 2004 become a member of the byb ausubaru board, theres tons of ej swaps goin on down there. Link to comment Share on other sites More sharing options...
