winginit Posted June 13, 2016 Share Posted June 13, 2016 1996 legacy wagon. steering pump pulley wobbles and can see it leaking, sounds like rocks in a can when running.. rebuild or JY ? thanks Link to comment Share on other sites More sharing options...
montana tom Posted June 13, 2016 Share Posted June 13, 2016 Definitely junk yard. I'm sure that you can rebuild yours but why bother, they are very available used. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 13, 2016 Share Posted June 13, 2016 ^^^ +1 Link to comment Share on other sites More sharing options...
winginit Posted June 13, 2016 Author Share Posted June 13, 2016 ok thanks Link to comment Share on other sites More sharing options...
somick Posted June 13, 2016 Share Posted June 13, 2016 I have rebuilt an EA82 steering pump. The big problem was the copper gasket that I had to substitute with the regular one. I am not sure if EJ series has the same pump though. Good luck, Sam Link to comment Share on other sites More sharing options...
winginit Posted June 13, 2016 Author Share Posted June 13, 2016 I have rebuilt an EA82 steering pump. The big problem was the copper gasket that I had to substitute with the regular one. I am not sure if EJ series has the same pump though. Good luck, Sam I have rebuilt an EA82 steering pump. The big problem was the copper gasket that I had to substitute with the regular one. I am not sure if EJ series has the same pump though. Good luck, Sam thanks Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 13, 2016 Share Posted June 13, 2016 Junkyard it. Probably just the bearing in the front that has gone bad, but if that gets bad enough it can cause the bushing at the back of the pump to wear. And if its wobbling its possible the pump rotor is getting worn as well. Those pumps are always around in junkyards because they really don't fail that often. Link to comment Share on other sites More sharing options...
