EA82t bent valve
So recently I picked up a nice 86 XT GL-10 that is nearly perfect but is leaking oil everywhere. I decided to do a shortblock out reseal. When tearing down the lh head I noticed the cylinder 4 exhaust valve is bent towards the top of the stem. It also looks like a few guides have dropped slightly. I was just wondering how common this is. In all the Subarus I've rebuilt I've never seen a valve bend at this spot. Also, amazingly, the rh head has no cracks between the valves. The lh head looks like a normal ea82 head.
I have heard of just one EA82T with a contact between valve and piston causing some bend after a timing belt slip or break. Yours makes the second out of three forums. Can you post up a pic of the removed valve?
I have had one head in need of a new valve guide as the valve stem had worn enough tp allow a3mm ? sideways movement in the head and cause a mystery performance problem. Fixed with a K-line insert and in my current EA82Mongrel.
I am wondering if you guide is nice and round inside to allow its angle and interference change, or just the guide slipped in to allow this - me thinks.
Its really hard to tell by looking at it that it is bent.  It does have a shiny spot where it was rubbing.  It was difficult to remove from the head and when I spun it in a lathe it was pretty obvious where the bend was.  I'll try to get a pic in the next few days.
I don't mean to start a tiff here, but based on deck height, piston height, TDC height and valve protrusion, it is impossible for the valve to contact the piston on an EA82 engine. Just for s&g, I took a bore scope to my XT when I rebuilt it and the clearance with the valve open and piston at TDC is huge in terms of interference specs. The only way I could see it happening is if the block or heads were shaved and the rod stretched. Any valve that is bent by piston contact is going to leave a mark on both especially if the pistons do not have valve reliefs cut/cast into them.
