Rambo Posted June 19, 2016 Share Posted June 19, 2016 Since I got this car it has had a clunking noises every now and then when I'm accelerating. It never bothered me until I replaced the cat converter. The clunking got worse after that so I went to the mechanic and asked what could be the problem. He showed me that the cat converter was pressed against the underside of the car. So I went home and readjusted it so it's clear from the underside, and though the clunking has lessened, it now is happening when I'm coasting and even in 4wd (clunking used to go away with 4wd. Do you guys know if there's a way to lower the cat converter or how to get rid of the noise? Link to comment Share on other sites More sharing options...
john in KY Posted June 19, 2016 Share Posted June 19, 2016 In my world I would first suspect a failing driveshaft. Link to comment Share on other sites More sharing options...
dfoyl Posted June 19, 2016 Share Posted June 19, 2016 I had the same problem with my Brumby/BRAT, the clearance is pretty tight. I found the best way was to (a) trim the cat sleeve, and ( add some washers under the bracket that comes from the gearbox that holds the exhaust system. Link to comment Share on other sites More sharing options...
bratman2 Posted June 20, 2016 Share Posted June 20, 2016 Going to step out on a limb here, could part of your problem be your motor mounts or transmission mounts? Maybe both? During acceleration would make me suspect of their condition. Link to comment Share on other sites More sharing options...
Rambo Posted June 20, 2016 Author Share Posted June 20, 2016 At first I suspected bad motor mounts, but I've had the sounds change on me everytime I readjusted the cat converter. And the sound seems like it's coming from where the front and rear cat meet, where the spring bolts attach. Is it possible that over tightening them can worsen the sound? I feel like the cat has enough clearance to not hit underneath the car when I accelerate hard (unless it can move up around 1/2"). Link to comment Share on other sites More sharing options...
