about 3 times now I have noticed an odd thing leaving for work in the morning. The right side headlight does not come on (drl) when I release the handbrake. One day, it stayed off for my entire 11 miles trip, another day it had a delay of about 1 or 2 seconds, then came on. This morning, it came on when I revved to leave my driveway (I have to reverse up an incline). This morning I was also able to confirm that the high beams work OK when this is happening. Also, the symptom persists if I use the stalk to switch on the low beams. When the light is off - no manipulation of handbrake or switches would make it illuminate. The problem 'seems' to be getting more common but - I have only seen it happen 3-4 times.
I think i recently read that the 2 'sides' of the system may have different relays? maybe I could swap them?
Edited by 1 Lucky Texan
Check the connector on the bulb first. Have had similar random on/off from the head lights on both of my cars and it's been due to corrosion/poor connection in the connectors.
Use some electric contact cleaner to clean them really well and spray them out with compressed air. Then apply anti-corrosive or silicone di-electric grease to the terminals.
Never hurts to change the bulbs either if you know they're a few years old, or if you've never changed them.
  • Like 1
  • 1 month later...
man - just doesn't seem like a bulb - more like an intermittent 'module' /relay ,but - has to be common to the stalk switch and the P-brake handle. The other day I could almost use the P-brake to send light the right side every alternate time I dropped it - when the light is off, it's off - when on, it seems as bright as the left side. No reduced glow or flickering.  This morning - both on and repeated activation of the P-brake never turned the right-side off. They both stayed in sync.
I'm gonna try to get under the hood at the bulbs at break this morning - maybe I'll spot something with the wiring......kinda reluctant to handle the bulbs and swap sides but it seems like it may be the next step.
no misbehavior so, it's kinda low priority right now.
I did find an H7LL bulb at Amazon - supposedly long life and built to heavy duty specs. If this seems like a bulb issue, I may get those. I rarely drive my WRX at night, so, not really worth short lifespan for more output.
