smutzla Posted June 21, 2016 Share Posted June 21, 2016 For some time the key has been hard to turn to "Lock" in the ignition of my 2006 Outback. It's a duplicate, not an original key, that was programmed with my fob, though I do have an original key available. Yesterday the key would not turn in either direction, slightly out of Lock position. My son (at LATTC in Los Angeles) to become a mechanic) got it out and after running some diagnostics thinks it could be worn tumblers from years of jiggling and pressure to get the key out OR the spring that allows the pin to move and allow the key to move into lock position is worn. Since the key won't turn in either direction now (something new as of yesterday, I don't know. He checked the electrical components which are fine. The Subaru dealer parts guy says ALL locks must be replaced, $475 just for parts, because changing out just one part would do something to the security system. Suggestions? My son was able to get the key out, but right now the car is going nowhere. Link to comment Share on other sites More sharing options...
wtdash Posted June 22, 2016 Share Posted June 22, 2016 HI - and welcome to the USMB, Did you verify the 'original key' wouldn't work either? If it's also dead, I'd just call another dealer (or 3) and verify the facts. I'd also look online/Ebay to see if you can buy the parts there. BTW (and for others' reference), most any Subaru parts department can cut you a key from the VIN, in case your dupe was done elsewhere. That's what I did for my '04 FXT and '02 WRX when I upgraded their separate key + fob = all-in-one keyfob. Link to comment Share on other sites More sharing options...
