soobiescoobie Posted June 7, 2004 Share Posted June 7, 2004 a kid i know says he has a mitsu****zu with 4 wheel steering does any one know if its true and if so, how does it work Link to comment Share on other sites More sharing options...
The Scooby Posted June 7, 2004 Share Posted June 7, 2004 i dont know about a mitsu car, but i know for sure the older body style preludes made by honda has all wheel steering. Link to comment Share on other sites More sharing options...
All_talk Posted June 7, 2004 Share Posted June 7, 2004 Yep, the Mitsubishi 3000GTS (aka Dodge Stealth R/T), was 4wd and 4ws. They were not the greatest performance car because they were a bit portly (about 3400lbs as memory serves). I think the rear steer angle is about 30% of the front and maybe locked out at some times. I know that the Prelude’s system counter steers at low speed, is inactive at moderate speeds and reverses to parallel steer at high speed (think lane change). Gary Link to comment Share on other sites More sharing options...
calebz Posted June 7, 2004 Share Posted June 7, 2004 If I recall correctly, My 3000GTs 4WS shut off at 30MPH.. Link to comment Share on other sites More sharing options...
carfreak85 Posted June 7, 2004 Share Posted June 7, 2004 Z32 300ZXTTs had 4ws. They had a hydrolic system. Lost of manufacturers in the 80s and early 90s played around with 4ws, some active (Like the Nissan and Mitsus) while many were passive (ie, the rear suspension geometry had toe out under certain conditions and points during its travel. Link to comment Share on other sites More sharing options...
subeman90 Posted June 7, 2004 Share Posted June 7, 2004 Mazda had a 626 turbo that had 4WS but it was part of a package. These cars usually had wheels on them that resembled xt6 wheels. Drove a prelude with 4WS once....WOW! that turned tight. Matt Link to comment Share on other sites More sharing options...
rugbyben Posted June 7, 2004 Share Posted June 7, 2004 I dont remember the make but it might have been a mitsu, but anway i think it had 4ws only when in reverse. that would be pretty nice for in city. Link to comment Share on other sites More sharing options...
gunablue Posted June 7, 2004 Share Posted June 7, 2004 If it's a 4 door sedan you would be referring to the Galant VR4. It was on the same platform as the Eclipse and had the 2 liter turbo'd engine and came with a 5 spd. It was their answer to the Legacy turbo....pretty sweet rides from what I understand....although some were problematic....they were only made in 91 and 92 if I remember correctly......but back to your question, they were awd and had the 4 wheel steering..... Link to comment Share on other sites More sharing options...
NoahDL88 Posted June 8, 2004 Share Posted June 8, 2004 as far as the 3000, i think that it has two phase steering, at low speeds its opposite, so that it can turn more sharply, /.../ \...\ At high speeds its same phase to make lane changes easier /.../ /.../ On an interesting note, i know that a lot of the big rigs with 4WS use the XT-6 electric rack, so that would make two things better, someone probably has a writeup on the internet, and its subaru, so that makes it that much better. Link to comment Share on other sites More sharing options...
Karl Posted June 8, 2004 Share Posted June 8, 2004 a friend of mine had a Alfa Romeo GTV-6 that had all wheel steering, but like someone said, only under certain conditions. If I remember correctly not only did it only work over a certain speed, but it also had to be at over a certain steer angle. Again this was a mid 80's car. It felt like the back end was slipping out from under you when it finally kicked in. Unfortunately the vehicle did little to dissuade my (poor) opinion of most Italian machinery. I'm sure it comes from my military history background, and knowing what garbage their armour was in WWII, but like I said this particular vehicle didn't help that opinion. Maintence nightmare. Link to comment Share on other sites More sharing options...
bushbasher Posted June 8, 2004 Share Posted June 8, 2004 infinit q45s have computer controlled 4 wheel steering as an option. My parents car does not, and are glad to be without it and all the extra problems associated (computer, sensors, hydraulic pump, hydraulic steering ram...) Link to comment Share on other sites More sharing options...
s'ko Posted June 8, 2004 Share Posted June 8, 2004 The Honda Prelude system was mechanical and active. It was set up on a hinge of sorts that would first go parallel and then counter turn. Depending on steering wheel input. Turn the wheel a little, the rear would go parallel, turn it a lot, wheel would go counter. Good idea since most high speed lane changing requires slight steering wheel inputs and parallel parking and such require lots of steering wheel input. Now the question at hand is how do we graft this into a BRAT ? BW Link to comment Share on other sites More sharing options...
MorganM Posted June 8, 2004 Share Posted June 8, 2004 Shouldnt this be in offtopic ? Link to comment Share on other sites More sharing options...
Guest taprackready Posted June 8, 2004 Share Posted June 8, 2004 Yes this topic should be in OFF TOPIC. But to add my 2 cents, Chevy Trucks can also be ordered with All wheel steering. Bill Link to comment Share on other sites More sharing options...
nipper Posted July 29, 2005 Share Posted July 29, 2005 There is passive 4 wheel steering where the cars rear end geometry allows for some toe in and toe out with body roll. There has been mechanical systems (which i think the early preludes are) hydraulic and electric systems. I think the only one that still has it (not sure) is GM on its full size pickup trucks. http://trucks.about.com/cs/4ws/a/4wheel_steering.htm. It was a neat idea, but didnt really sell. nipper Link to comment Share on other sites More sharing options...
nkx Posted July 30, 2005 Share Posted July 30, 2005 as far as the 3000, i think that it has two phase steering, at low speeds its opposite, so that it can turn more sharply, /.../ \...\ At high speeds its same phase to make lane changes easier /.../ /.../ iirc, Z32s with the 'hikas' (not sure on spelling) system work the same way. hydrolic piston in the rear controls the steering. Link to comment Share on other sites More sharing options...
